Insteon Explorer - Setup
Download
This step is required with a new PLC or anytime the PLC is reset. It may
also be occasionally necessary if the PLC is not acting normally.
Clear
Clears all ID's from the PLC internal database. Usually a good idea to
perform this step prior to adding PowerHome Insteon device ID's to PLC.
Add Min
Add's PowerHome Device ID's to the PLC internal database in a minimal
format. This is the default method and will add the minimum amount of
information in order for PowerHome to function properly. If it is desired
for the PLC to have fully constructed link information, then use the "Add
Full" option instead.
If the PLC is new or has been reset, this is a required step in order for
PowerHome to function properly. Also may be required if Insteon Devices
have been manually added to PowerHome. Usually best to Clear PLC Database
prior to executing this function.
Add Full
Add's PowerHome Device ID's to the PLC internal database in full linked
format. Use this method if the PLC will have custom code or be connected
to an application that requires the PLC to have fully formed link
information. It is not necessary to use this option if the PLC will be
used only with PowerHome.
Use the "Clear" option to clear current PLC device ID's before adding new
device ID's.
Links
Clears stored Insteon Device link information from PowerHome database.
Does NOT affect actual link data stored within Insteon devices. Useful
when you want to have PowerHome rediscover link information from Insteon
devices.
Devices
Clears stored Insteon Device data from PowerHome database. Use with
caution. You will either have to manually re-enter or Auto Discover
Insteon devices in order for PowerHome to work properly after using this
command.
Create
This option will scan the currently connected PLC for stored Device ID's
(Insteon Addresses). Any ID's not found in the PowerHome Insteon Devices
table will be queued for Pinging. Pinged devices that respond properly
will then be automatically added to the PowerHome Insteon Devices table
with a default ID in the form of "NEW SPIDER ??" where ?? is a sequential
unique number.
This option is useful for quickly getting Insteon Devices into PowerHome
if the PLC has already been configured to recognize them.
Auto Discovery
Places PowerHome and the PLC into Auto Discovery mode. This will allow you
to register Insteon devices within PowerHome without having to manually
key in their unique address. Especially useful if switches are already
installed and you don't wish to remove the faceplate to read the address.
Once Auto Discovery is turned on, you must visit every Insteon device and
place it in linking mode by pressing the set button for 3 seconds or the
On button for 10 seconds. As soon as the device enters link mode, you will
hear the WAV file and/or TTS confirmation if you've enabled those options.
Once link mode has been entered and confirmation received, press the On
button briefly to exit link mode. Make a list of the order in which you
visit the switches. When done, return to PowerHome and turn off Auto
Discovery mode. Your Insteon devices will have been automatically entered
into the PowerHome database for you with an ID that begins with "NEW
DEVICE XX" where XX will be a number in the order that the devices were
discovered (hence the need to make a list). You will want to rename the ID
and Description appropriately.
