Posted: July 11 2020 at 16:55 | IP Logged
So happy to see a new ph_run1() function
that should allow for hiding pop up windows when
running commands from within PH.
Because the new FireTV plugin that comes with PH
doesn't provide any feedback for triggers, I am
looking into developing my own solutions (having ADB
write to a text file and having PH file monitor
trigger off that)...Anyway...that is another story.
What I am trying to accomplish presently is to run
ADB commands from PH without a pop up window.
Home Command:
ph_run("c:\adb\adb.exe shell input keyevent 3")
Launch Netflix:
ph_run("adb shell monkey -p com.netflix.ninja 1")
Launch HDHomeRun:
ph_run("c:\adb\adb.exe shell monkey -p
com.silicondust.view 1")
Ect, Etc,...
Without a command window flashing on the screen as the
command executes.
Dave - I think I have tried almost every variation on
the ph_run1() command. Any insight you could provide
here?
One last one...this is how I see which application is
on screen:
ph_run("adb shell dumpsys window windows
>c:\powerhome\ADB-Control\ADB_windows1.txt")
The above command (which outputs a text file for the
file monitor) works in a CMD window, but not from
within PH.
Edited by smarty - July 11 2020 at 17:58
Posted: July 11 2020 at 22:10 | IP Logged
Steve,
You've got a couple of options listed below. Both will run ADB without opening a window.
Without Shell Execute:
ph_run1('c:\android_sdk\adb.exe','kill-server','',0,8)
With Shell Execute:
ph_run1('c:\android_sdk\adb.exe','kill-server','',0,20)
The following worked for me to run ADB without a window and redirect output to a file:
ph_run1('cmd.exe','/c "adb shell dumpsys window windows>ADB_windows1.txt"','c:\android_sdk',10000,72)
and:
ph_run1('cmd.exe','/c "adb shell dumpsys window windows>ADB_windows1.txt"','c:\android_sdk',10000,84)
and another where I redirect the file output to a different directory:
ph_run1('cmd.exe','/c "c:\android_sdk\adb.exe shell dumpsys window windows>adb_windows1.txt"','c:\users\hello there\desktop',10000,84)
Out of curiosity, what kind of triggers would you like to be fired for the FireTV plugin? It might be simple enough for me to add.
