        | kemporama Senior Member
          This problem has been driving me crazy for months. I have a timed event setup that toggles my "TIME_OF_DAY" variable between DAYTIME or NIGHTTIME.  This works correctly.  For some reason the 2nd line in the macro I show in the below will always just proceed to step 3 and turn the light on even if the variable is currently set to DAYTIME or anything else.  I'm totally stumped because I copied this exact same command from my old PH system that worked fine, but it refuses to work for me now.  What am I doing wrong?  Thank you in advance!
           | Posted: June 12 2017 at 23:00 | IP Logged |   |
          Kempo,
           | Posted: June 12 2017 at 23:14 | IP Logged |   |
 In line 20, change the command from "Formula" to "Jump"
          Wow, I knew it was going to be something dumb I was missing.  Thank you!!
           | Posted: June 12 2017 at 23:17 | IP Logged |   |
