PowerHome Programming
Subject Topic: Insteon 2663-222 Dual Outlet Link Post ReplyPost New Topic
moniputer
Posted: March 20 2015 at 17:34 | IP Logged Quote moniputer
I have one of the new dual Outlet links, On/Off Outlet
(2663-
222).
It only has one Insteon address but two controlled
outlets. I tried setting it up as a 2473S but that
didn't work.
Anyone have one of these working?
Edited by moniputer - March 20 2015 at 18:16
Back to Top View moniputer's Profile Search for other posts by moniputer
Posted: March 20 2015 at 18:28 | IP Logged Quote dhoward
Moniputer,
I have one of these setup and working. For a device
type, I just set it to *Autodetect Type* so that it
would create a new entry for me with appropriate Cat
and Subcat entries in the Types table and then set the
description to 2663-222 Dual OutletLinc. Set the Ctlr
and Resp groups both to 2 and the rest of the settings
should be ok.
Doesnt seem to be a way to control the second outlet
though other than a group command. Just link (at least
the second outlet) to the PLM with the PLM as
controller and second outlet as responder and then
control the group to turn the second outlet on and
off.
moniputer
Posted: March 20 2015 at 18:33 | IP Logged Quote moniputer
Thanks Dave!
Joe
smarty
Posted: September 21 2016 at 19:22 | IP Logged Quote smarty
Another Outletlinc question...
Is there ANY way to query the On/Off state of the SECONDARY outlet on this device?
I can query the primary outlet. I have set up a PLM group to turn on and off the secondary outlet....but for "recovery" purposes, I am still looking for a way to query the on/off state of each individual outlet.
Posted: September 22 2016 at 12:49 | IP Logged Quote dhoward
Steve,
Took a look at the release notes and there is a way but it's unlike any other device.
You'll want to send a status request with a 1 for the cmd2 like this:
ph_insteonwithret("OUTLETLINC",25,1).
The response will be either 0,1,2, or 3 with 0 meaning both outlets are off. 1 means Top outlet only is on. 2 means Bottom only outlet is on. 3 means both outlets are on. So you
could do something like this:
if(ph_and(ph_insteonwithret("OUTLETLINC",25,1),2) > 0,"Bottom Outlet On","Bottom Outlet Off")
smarty
Posted: September 23 2016 at 07:17 | IP Logged Quote smarty
Super helpful, Thank you!
Before asking the question, I did search around the web to see what I could find. Can I ask where you found "the release notes" for this device?
Posted: September 23 2016 at 10:30 | IP Logged Quote dhoward
I believe off the SmartHome Insteon developers website
that you have to pay to have access to.
Tiffansy
Posted: November 13 2017 at 00:53 | IP Logged Quote Tiffansy
Same Question
http://sizegeneticsresult2020.inube.com/
https://sizegeneticsreview2020.jimdofree.com/
Edited by Tiffansy - January 16 2020 at 09:05
Tiffansy
Back to Top View Tiffansy's Profile Search for other posts by Tiffansy Visit Tiffansy's Homepage
Posted: November 13 2017 at 12:15 | IP Logged Quote dhoward
cmd2 like this:
on. So you
