Posted: March 16 2005 at 11:07 | IP Logged
Will,
The current SDK (as X-10 calls it) is just an active-x interface to their ActiveHome Pro software. The big drawback at this point is the current SDK does not allow you to individually address X-10 modules separate from sending them a command. The standard X-10 protocol (and the way PowerHome is designed) requires two commands to turn a light on. The first is an address command followed by the function command (on, off, etc). This type of addressing is not currently available.
However, from reading the X-10 developers forum, X-10 has stated they will soon release the actual protocol specifications. This will allow us to write a driver such that the individual addressing will be available and ActiveHome Pro does not need to be installed and running.
Support for this module is definately planned, just waiting for the release of the "actual" protocol. If it does not materialize soon, I'll put together something that utilizes whats currently available but it will have reduced functionality since individual addressing is not available.
