judetf Senior Member
Posted: April 23 2008 at 08:12 | IP Logged
Before I start mucking about (love Jeff's phrase) I thought I'd check for advice first:
I have a KPL button set for home/away status, but we are finding that we often forget to hit that button when we get home. So I thought I would create a trigger for _any_ KPL or Switchlinc button press, and have that mean that we are home and run the home macro. (And I plan to disable that trigger once we get home, so that it's not running constantly.)
My question: what should I use for Trigger Type and Trigger ID? Only "Insteon Device Chg" seems to allow "any" as the ID, but I don't think that will work because I have macros and timed events that run if we are _not_ home, and I suspect they would cause a "Device Change" trigger to fire.
So, looking for advice on how to fire a trigger on _any_ button/switch press, but not on other PH-driven actions.
Thanks for any assistance.
jtf
Posted: April 23 2008 at 11:28 | IP Logged
You can check the trigger's temp variables for the source of the message (i.e. don't fire if it originates from anything other than that device).
Look here for details.
Posted: April 23 2008 at 13:39 | IP Logged
Perfect. We may have a winner. I set my 'home' trigger to fire on Insteon Device Change, Any trigger ID, Any trigger ID number, and Any trigger value, and I set the Boolean field to:
case([TEMP4] when 4 then 1 else 0)
If all goes according to plan, it will only fire when I physically press a KPL/Switchlinc. This is based on Dave's statement that Temp4 value 4 = "Direct Command from device."
I have tested remotely and know that PH-based device changes do _not_ cause the trigger to fire. As soon as I get home I'll try pressing some random button and see if it fires.
jtf
Posted: April 23 2008 at 13:49 | IP Logged
jtf,
Tonys got you covered. If you need a little more detail, I would probably use the "Insteon Device Chg" trigger with [ANY], (Any), (Any) and place the following formula in the Boolean field:
[TEMP4] = 5 and ([TEMP9] between 17 and 24)
This will cause the trigger to only fire on incoming broadcast commands from switches (essentially button presses). I would then use the "ph_enabletrigger()" and "ph_disabletrigger()" functions to enable the trigger *only* when you're away and disable it as soon as you arrive home (essentially when the trigger fires...it will disable itself).
Posted: April 23 2008 at 14:04 | IP Logged
Fine, I'll do it your way instead of mine. You're just showing off b/c my post came in before yours did... ;)
Already had the enable/disable trigger functions added to the respective home/away macros that I run. The logic seems flawless. What could go wrong? (Can't wait to buy an Elk system and start putting it all together! I'm sure _nothing_ will go wrong then!)
jtf
