Subject Topic: Vista Volume Control Post ReplyPost New Topic
smarty
Posted: December 25 2008 at 13:56 | IP Logged Quote smarty
For those of you that use Vista, you probably already know it has some unique volume control "capabilities".
PH has:
ph_setsysvol()
ph_getsysvol()
ph_getsysvolmax()
ph_getsysvolmin()
But these appear to only set PowerHome's application volume, not the OVERALL volume of the computer.
Ideally, I would like to be able to control PH's volume, other applications volume, AND the overall system volume.
Has anyone else figured out a work around?
BeachBum
Posted: December 25 2008 at 14:06 | IP Logged Quote BeachBum
I use ph_setsysvol(20208) with Vista and it sets Vista volume to 50.
Pete - X10 Oldie
smarty
Posted: December 25 2008 at 19:20 | IP Logged Quote smarty
Yes, setting the volume is presently possible using the commands I mentioned, but is there anyway to set the OVERALL volume (and not just the application volume) when multiple applications are opened?
nadler
Posted: December 25 2008 at 19:50 | IP Logged Quote nadler
In XPsp2 those commands do control the overall PC system
volume and not the application volume. Not sure about
Vista though.
BeachBum
Posted: December 25 2008 at 20:14 | IP Logged Quote BeachBum
Most of my apps have their own volume control but I don’t know of any way to have PH control them.
Pete - X10 Oldie
theowl
Posted: April 22 2012 at 17:18 | IP Logged Quote theowl
I know this topic is years old, but here is how I just handled this on my Win 7 system.
1. Downloaded nircmd from http://www.nirsoft.net/utils/nircmd.html
2. Unzipped the files and placed them in c:\windows\
3. Replaced ph_setsysvol() with the following:
a. Set system var TEMP1 to the desired volume number (between 0 and 65000)
b. ph_run('nircmd.exe setvolume 0 [TEMP1] [TEMP1]')
Explanation: I'm telling the system to set the right and left channels of main volume (0) to whatever is in TEMP1. This seems to be working fine on a Win 7 32bit system.
Hope that help someone, this conversion to Win 7 has been very interesting so far. Now I'm off to figure out why firecracker can't get a signal to the A/V center.
Peace!
Back to Top View theowl's Profile Search for other posts by theowl
