Subject Topic: Macros disabled Post ReplyPost New Topic
Mitch
Posted: December 27 2010 at 13:04 | IP Logged Quote Mitch
I seem to be creating more problems than I am solving lately. I was in the middle of editing/testing a macro when they stopped working - all of them. I could not get them to run from triggers or from the run window. I restarted PH and that seemed to fix it, but after running several minutes then I get the same problem - all macros are disabled. Yikes!
Back to Top View Mitch's Profile Search for other posts by Mitch
BeachBum
Posted: December 27 2010 at 13:15 | IP Logged Quote BeachBum
What do you mean by disabled? Their checked disabled or they will not run from the command window. And what Windows are you on?
Pete - X10 Oldie
Mitch
Posted: December 27 2010 at 15:33 | IP Logged Quote Mitch
They just will not run. If I reinitiate or restart PH they seem to work fine for about 10 minutes, but then they just stop working. Will not execute from the run window or from a trigger. I could not see anything marked as disabled - where would I look?
Mitch
Posted: December 27 2010 at 15:36 | IP Logged Quote Mitch
I also get an error window if I try to run a macro after reinitiating ph - it goes away too fast to read the whole thing.
BeachBum
Posted: December 27 2010 at 15:41 | IP Logged Quote BeachBum
My brain is full of turkey… I was thinking disable as in triggers. Ok here’s the same old question have you reinstalled or changed anything. You might try running PHUPG from the powerhome directory.
Pete - X10 Oldie
BeachBum
Posted: December 27 2010 at 15:47 | IP Logged Quote BeachBum
To add more to it.. I see you are playing with startup. I might suggest you undo that and get the INI back to where you ran ok. The startup may be flashing the message at you. If that resolves the macro issue then we can go after the JDS issue. Didn’t know people still used them.
Pete - X10 Oldie
Mitch
Posted: December 27 2010 at 15:50 | IP Logged Quote Mitch
The error first occurred before I started messing with startup, but will undo the changes to the ini just to be sure. Meanwhile I'm rebooting the cpu just to make sure there is not some gremlin sitting in the memory.
smarty
Posted: December 27 2010 at 15:56 | IP Logged Quote smarty
The "Startup" macro is to be called by a trigger from the system process of "Startup".
Messing with the .ini is an older method I believe (not sure if it works or not, but I KNOW the startup triggers work - cause I use them).
BeachBum
Posted: December 27 2010 at 15:58 | IP Logged Quote BeachBum
True statement that’s why I had him back off the INI fix.
Pete - X10 Oldie
Mitch
Posted: December 27 2010 at 16:30 | IP Logged Quote Mitch
Ok - found the system trigger and set it to run the startup macro on startup and a second to run it when reinitializing.
Meanwhile I narrowed down the macro lockup - it happens when one that I was editing is run. I could not see anything at all wrong with the formulas or commands, but I deleted that macro and rewrote a new one from scratch. That seems to have done the trick.
Thanks for your help!
Mitch
