Subject Topic: syntax error? Post ReplyPost New Topic
jeffw_00
Posted: January 15 2011 at 15:45 | IP Logged Quote jeffw_00
If I cut/paste these properly to this message, then all the nesting is correct. Still, PH claims either of these has syntax errors, can someone enlighten me?
thanks!
They're both JUMP commands
if(ph_and([LOCAL8]=0,[LOCAL9]=0),2,if(ph_and([LOCAL8]>0,[LOCAL9]=0),1,if([LOCAL9]>0,4,6)))
if(ph_and(ph_getvar_n(1,8)=0,ph_getvar_n(1,9)=0),2,if(ph_and (ph_getvar_n(1,8)>0,ph_getvar_n(1,9)=0),1,if(ph_getvar_n( 1,9)>0,4,6)))
Posted: January 15 2011 at 17:42 | IP Logged Quote dhoward
Jeff,
I think your problem is in the use of the ph_and function. This
function is a bitwise function and must operate on numeric values.
By having a comparison as values, youre passing booleans which will
cause a syntax error. The proper logical operator for AND is just the
word and.
Hope this helps.
Dave
jeffw_00
Posted: January 15 2011 at 18:03 | IP Logged Quote jeffw_00
thanks dave - wasn't sure AND would work - couldn't find it in the help.
best
