mmunnelly Newbie
Posted: August 19 2014 at 23:33 | IP Logged
Hey Dave and Gang:
With the excitement of 2.1.5a complete, I have started
looking at the thermostat stuff with 3.1.5A.
I note that in the help file, you talk about the I2CS
configuration for setting up the thermostat. My
question to you, will 2.1.5a, the 2414U and the 2441V
play nicely together? With the old version it did, but
i'm wondering if it does with the new ones.
I followed the instructions in the help file (aside from
the fact that your database types had a thermostat 2441TH
and mine only has the 2441V RF interface, I set up the
analog IO's as per instructions and they went into the
database, I set the pole frequency to 300 but they never
bring back any results.
I set up a macro for ph_getanalog("ID"), and used the
TS1CSP and the TS1HSP (I copied your database entries)
and the CSP would result in -2 and the HSP would result
in -100.
If it won't work, then i'll just pick up one of the
serial I2CS adapters, but if I am doing something wrong,
i'd like fix it.
Mucho Thanks.
Mike
Edited by mmunnelly - August 27 2014 at 09:50
