        | GCollins Groupie
          Hi PowerHome Experts,
           | Posted: March 09 2015 at 16:49 | IP Logged |   |
 I'd like to have a single macro that runs an automated lighting schedule whenever we are away from home.  While that seems like one of the more basic uses for
 PowerHome, I haven't seen anything comprehensive posted here.  However, I have read discussions of various PH functions and want to apply what I've learned to my
 application.
 The first part of the scheme uses a trigger to set the value of a global variable {AWAY} to either 1 (true, Elvis has left the building) or 0 (false, he's come back
 home).
 The second part uses a single timed event to launch the macro.  It's set to run daily beginning at some capped Random+ number of minutes after Dusk, conditional on
 the value of the {AWAY} variable per this function in the Boolean column:  if("{AWAY}"="1", 1, 0)
 The third and final part is the macro, which gradually turns various lights on/off over the next few hours leading up to Elvis' normal bedtime.  It goes like this:
 10  Goto Label    if("{AWAY}"="0", "END", "nextLINE")   'Check if system taken out of AWAY mode, break out of macro if so, else fall thru
 20   X10         &nb sp; xxx                                      'Turn   some light on or off
 30   WAIT         &n bsp;1800 + (60 * (ph_random (10)))        'Wait some fixed  # of seconds (1800) plus some additional random # of seconds
 40   ...         &nb sp;         &nb sp;         &nb sp;         &nb sp;         'Ad ditional series of 3 statements like above for different lights and time intervals, and so on
 500 LABEL         END
 As a fairly new PH user I'd appreciate any feedback.  Are there any fatal flaws or unexpected negative consequences in this approach?  Is there a more efficient way
 or better commands to use?
 I'm already having trouble getting the Goto Label command to work, which I've posted about in a separate thread.  My other concern is with the WAIT command; I've seen
 mentioned that the similar DELAY command causes ALL PowerHome processing to pause.  I wouldn't want that.  It's important that other timed events, macros and triggers
 (like Elvis coming home and toggling the Away button) continue to function while this one particular macro is in its various wait states.  My testing thus far
 indicates it's not a problem, but I just want to be sure.
 G
 Edited by GCollins - March 09 2015 at 16:52
        | TonyNo Moderator Group
          What I do in this situation is to use Timed Events via a macro called Create Random Events. It generates random on/off times for various lights...
           | Posted: March 09 2015 at 17:51 | IP Logged |   |
 Create Timed Event | FOYER MOTION | string( datetime( today(), relativetime( 00:00:00, [DUSK] + rand( 3600) )))
 Create Timed Event | SINK LIGHT OFF | string( datetime( today(), relativetime( 00:00:00, 79200 + rand( 7200) )))
        | GCollins Groupie
          Hi Tony,
           | Posted: March 09 2015 at 19:00 | IP Logged |   |
 That's interesting.  If I understand properly, I would
 keep a daily repeating event that checks the {AWAY}
 variable, and when true would execute a macro that
 creates a bunch of one-shot timed events for various
 other macros.
 Is this a more efficient use of the system versus a
 single macro that is stepping slowly though its
 commands over the course of a few hours?
 Also, how do you cancel the random one-shot events
 when the homeowner returns?
          GC,
           | Posted: March 09 2015 at 23:38 | IP Logged |   |
 This is basically what I do as well. I have a global
 variable such as your AWAY var that is set to 1 when
 Im gone and 0 when Im home. A timed event runs daily
 that checks the value of this GV (can be done in the
 boolean field of the timed event). If conditions are
 met and the timed event executes, it launches a macro
 to create my random 1 shot timed events.
 In my macro, I made a list of all possible items that
 I may want to have randomly turned on. I then assigned
 a percentage chance of whether that device would
 actually get switched for this days random events. If
 it does get turned on, I then create a couple of one
 shot timed events (one for on, one for off) with
 suitable random start/stop time values.
 A couple of ways to handle the already created timed
 events when the AWAY var changes. I use the
 ph_createtimedevent1 function (so I have full control
 over the parms). You can include in the boolean
 parameter a check for the AWAY var and just leave the
 timed events alone as they'll fire (but won't execute)
 and then will be gone. The other way you could handle
 it is to give all the one shot events a leading prefix
 on the ID and then create a trigger on the AWAY var to
 run a SQL statement to delete all timedevents with an
 ID beginning with the prefix.
        | GCollins Groupie
          OK, that's two valued suggestions to go with the
           | Posted: March 10 2015 at 09:36 | IP Logged |   |
 |  create timed events approach.  I like the percentage
 concept and the boolean method for checking the AWAY
 var (just like I do when launching the whole thing,
 duh).
 I will move to this approach, but it's a bit more
 complex so I may put it off for a while.  Until then,
 is there anything terribly wrong with my use of the
 WAIT statements as I have it set up now?
 Also Dave, would you mind sharing a line of your macro
 code that uses the ph_createtimedevent1 function?
          G,
           | Posted: March 11 2015 at 21:35 | IP Logged |   |
 You should have no problem using the Wait command. It
 won't hold up any PowerHome processing. However, it
 will hold up the rest of the macro lines that appear
 after the wait (which may be what you want) so your
 lights or other "control" statements will be
 sequential.
 Below is a sample of what a randomly generated timed
 event would look like:
 In this macro, the first checks whether to skip the
 generation of this event. Basically there is an 85%
 chance that we will control the KITCHEN light. Line 20
 is the creation of the timed event. Im using a random
 +/- offset of 40 minutes from the default starttime of
 08:00:00. The next parameter (3) is for an action of
 Device Control string (this is missing from the help
 file). The next line is the event to turn the light
 off. Basically you would duplicate these 4 lines over
 and over for each light/device you want to randomly
 turn on.
 Edited by dhoward - March 11 2015 at 21:42
        | GCollins Groupie
           | Posted: March 15 2015 at 21:29 | IP Logged |   |
 Yes, I want my AWAY events to be sequential (yet at
 somewhat random spacing), for now. Mimics our "routine".
 Thanks for the peace of mind on the WAIT statement.
 Thanks also for the examples, great for the future.
 G
