TCassio Newbie
Posted: April 10 2005 at 12:25 | IP Logged
You state that Powerhome supports the powerlinc controller, I don't see that choice in the X10 controllers setup. How do I set this up.
T.
Posted: April 11 2005 at 15:39 | IP Logged
It depends upon the version you are using. The first version to support the PowerLinc USB was 1.03.4.3 (which did not work because the timer object was missing).
The latest beta (version 1.03.4.4) should fully support the PowerLinc USB.
Let me know if you have any problems,
TCassio Newbie
Posted: April 11 2005 at 18:51 | IP Logged
I just installed version 10344 and I don't see support for the PowerLinc controller in the setup portion of the program.
Tony
Posted: April 11 2005 at 23:19 | IP Logged
I just checked out version 1.03.4.4 and found it.
Launch the PowerHome Explorer, navigate to Setup->Controllers->X-10 and drop down the box for X-10 Controller 1. PowerLinc USB should be at the very bottom of the list.
Let me know if you are still having trouble.
