AllanMar Groupie
Posted: April 15 2007 at 10:04 | IP Logged
I've disabled web logging in the setup section. However it is still logging. I'm not sure why? It seems whatever I disable logging for has no effect.
Has anyone else experienced this?
ginigma Senior Member
Posted: April 15 2007 at 17:54 | IP Logged
Did you restart or reinitialize PH after making the changes? Whenever you make a change to something in the Setup section, you need to do that.
AllanMar Groupie
Posted: April 16 2007 at 15:05 | IP Logged
Yes. I made this change when I first installed powerhome. It has been reintialized/restarted atleast a dozen times since then.
Posted: April 16 2007 at 16:09 | IP Logged
Allan,
I just tested it here (version 1.03.4.10) and it worked ok so it shouldnt be a problem with the program. Most likely, something is wierd with the data in the pwrhome.ini file.
If you want, email me your pwrhome.ini file and I'll see if anything looks out of place.
