mustangcoupe Super User
Posted: June 08 2007 at 19:13 | IP Logged
Any updates on controlling/updating the ELK via the ethernet expander?
I dont have my PH computer nearby, and couldnt get the virtual serial port software working...(but I think that's me)
HA newbie
PowerHome - UPB - ELK
Posted: June 08 2007 at 20:31 | IP Logged
Todd,
My Elk is off line due to construction installation (still!!), but I would be willing to help you try to diagnose why your not able to get the virtual serial port software to work.
Like you, I am also curious about the next release, but the VSP software really works well for me (as far as interacting with the elk via the ethernet module).
....at least it did when it was hooked up....
Steve
jack1747 Newbie
Online Status: Offline Posts: 14
Posted: June 20 2007 at 11:42 | IP Logged
mustangcoupe wrote:
I dont have my PH computer nearby, and couldnt get the virtual serial port software working...(but I think that's me) |
I too need to connect via the ethernet expander.
What is "virtual serial port software"?
Posted: June 20 2007 at 12:45 | IP Logged
See this thread about the freeware HW Virtual Serial Port
LINK
This is a work around (using ethernet only) until PH talks directly to the ELK. I think it has been mentioned that Dave will render this workaround obsolete (not needed) with the next beta release of PH.
Edited by smarty - June 20 2007 at 12:48
jack1747 Newbie
Posted: June 20 2007 at 15:37 | IP Logged
LINK
This is a work around (using ethernet only) until PH talks directly to the ELK. I think it has been mentioned that Dave will render this workaround obsolete (not needed) with the next beta release of PH. |
Thanks. HW VSP was easy to install but I think I might be in over my head here. I think I will wait for the "paint by numbers" point and shoot PH/Elk.
WayneW Groupie
Posted: June 24 2007 at 09:33 | IP Logged
I have used the HW_VSP tool to connect the my.Elk HomeSeer script to my Elk XEP for a year or two. Please post if you have any configuration questions and I will try to help.
Make sure you uncheck "NVT enable" in the Settings tab.
