Subject Topic: Help needed with Extended Codes Post ReplyPost New Topic
Opus
Posted: December 10 2002 at 02:17 | IP Logged Quote Opus
I just bought a new Leviton 16383-WI, and it supports extended codes but I have no idea how and what codes.  Basically I have macros setup for things like movie watching, night time snack, morning lighting..... I want to run a macro and have the light go to a set brightness for each macro.  The way I do this with a normal X-10 device is a "on" command followed by "dim x%."  From what I read this switch will go to a set level via extended codes, but a search of the net has only told me this "there are 64 levels; i.e., 0-63 with 0 being Off, 1-62 being presets from dim to bright with soft start, and level 64 being an immediate full on without soft start."  Can anyone tell me how and what extended codes to send?
TIA!
Back to Top View Opus's Profile Search for other posts by Opus
Posted: December 10 2002 at 08:49 | IP Logged Quote TonyNo
Try these...
http://www.act-solutions.com/kingery14.htm
...and...
ftp://ftp.x10.com/pub/manuals/xtc798.doc
Tony
Opus
Posted: December 10 2002 at 16:14 | IP Logged Quote Opus
I looked at those sites yesterday but they didn’t help, but I spent a little more time today and I got it to work.  Here are the long steps it took me to get the right answer.
The basic information from the web site provided me with the codes.  For example:  Here is the extended code: Data= 00111111 (H#3F), Type= 0011 (H#3), Command= 0001 (H#1).  This should send the command to turn the light on full without dimming up.  So now how do I get that command sent.  Well in my macro I tried this:
SEQ |  TYPE   |  ID  |  VALUE           |  SEND KEYS/TTS/DIM/FORMULA
10  | X-10 1  | B    | 14 EXTENDED      | 0011111100110001
I test it and check my Log and here is what it shows:
X-10 controller 1 transmission of House code: B, Unit Code: 14, Extended Data: D4B1
But that’s not the right Hex code.
So I thought maybe it needs the Hex so I put in 3F31 in the Send keys then the log shows this:
X-10 controller 1 transmission of House code: B, Unit Code: 14, Extended Data: 0000
Finally I tried the decimal value 16177 and the log showed this:
X-10 controller 1 transmission of House code: B, Unit Code: 14, Extended Data: 3F31
So now I have the extended code right and it seems to work.
So after some trial an error I got it, maybe I missed it in the manual but I did not see anything about sending extended codes and the need to be in decimal.
Dave why do the extended codes use decimal and not Hex or even binary?
All:
Here is how to use extended codes for Lights:
In a macro use the ID of the units House Code, and then pick the unit number with the EXTENDED extension.  In the Send keys field put one of the decimal values listed below.
% Light
DEC
OFF
49
2
305
3
561
5
817
6
1073
8
1329
10
1585
11
1841
13
2097
14
2353
16
2609
17
2865
19
3121
21
3377
22
3633
24
3889
25
4145
27
4401
29
4657
30
4913
32
5169
33
5425
35
5681
37
5937
40
6449
41
6705
43
6961
44
7217
46
7473
48
7729
49
7985
51
8241
52
8497
54
8753
56
9009
57
9265
59
9521
60
9777
62
10033
63
10289
65
10545
67
10801
68
11057
70
11313
71
11569
73
11825
75
12081
76
12337
78
12593
79
12849
81
13105
83
13361
84
13617
86
13873
87
14129
89
14385
90
14641
92
14897
94
15153
95
15409
97
15665
98
15921
Full On
16177
For example I want my B-14 light switch to come on to 30% brightness no matter what it currently is set to, so my macro would look like this:
SEQ| TYPE  |ID| VALUE       |  SEND KEYS/TTS/DIM/FORMULA
10 |X-10 1 |B | 14 EXTENDED | 4913
And now play your macro and check your status.
I don’t know how well this works for other controllers as I have only tested on a Leviton 16383-WI.
NOTE: The Full ON code (16177) above does not dim up, to dim up use the X-10 ON command if you do not have the preset dim, if you have preset dim then us the 98% light level code (15921) fallowed by the a full on code (16177).
Good Luck!
Posted: December 10 2002 at 20:47 | IP Logged Quote dhoward
Opus,
Well it looks like you've found the right answer in a very painful way .  Yes, you are correct and PowerHome expects the extended data in decimal.  However, when you select an X-10 extended command, you can right-click in the Send Keys field and select the "Extended Builder" from the pop-up menu.  This will bring up a window similar to the formula builder and will allow you to very easily select the extended actions you want and will create the correct decimal codes for you automatically.
Sorry you had to figure this out the hard way but it was fun doing it wasn't it?
Opus
Posted: December 10 2002 at 23:11 | IP Logged Quote Opus
Geez!
That was the answer I was looking for , well now I know both ways!  I knew there had to be an easier way, did I over look that info in the PDF manual?
Opus
Posted: December 12 2002 at 19:31 | IP Logged Quote dhoward
Opus,
I searched through the manual  and it was right there on page 42...just kidding .
After a thorough search, I see that it's an omission on my part.  I'll be sure to correct it in the next release though.  I thought for sure I had the extended builder in there but writing manuals are not my strong point.
