Subject Topic: Mysterious Flicker Post ReplyPost New Topic
BeachBum
Posted: March 29 2008 at 13:33 | IP Logged Quote BeachBum
I have a track controlled by an Insteon Dimmer that flickers when Insteon traffic is coming across the power line. I have tried both X10 and Insteon dimmers in the circuit and both have the same problem. You only notice this if the lights are dimmed. It flickers bright for each Insteon traffic. I have removed all low voltage lights from the track and still have the problem. I even tried to isolate it down to 1 light. A standard dimmer switch (non Smarthome ) on a lamp on the same circuit does not flicker. Other tracks on the same phase that have Insteon dimmers installed don’t flicker. The reason why I started to notice this is because I now have scan running. Anybody got any thoughts on this problem….
Pete - X10 Oldie
bhlonewolf
Posted: March 29 2008 at 16:04 | IP Logged Quote bhlonewolf
I see this on an old manual dimmer where I have a reasonably significant load (11x 40-watt) and it's dimmed to a low level. I haven't seen this on an insteon dimmer -- I would've thought they'd be "immune" to insteon traffic causing brightness spikes like that, but apparently not. Not much help, but I guess it's possible -- interesting that a standard dimmer does NOT show this...
Back to Top View bhlonewolf's Profile Search for other posts by bhlonewolf
jeffw_00
Posted: March 29 2008 at 17:41 | IP Logged Quote jeffw_00
I have a ceiling fixture that has a couple of CFLs, and (for load) 1 incandescent bulb, controlled by an old-style RF remote control light switch (receiver in switch box w/local ctl, battery-powered transmitter located elsewhere). This is one of the 'two-channel (A or B) models you get at home depot for $20.
It flickers slightly whenever there is insteon traffic. (but not for X-10 traffic). Must be a filtering thing. Fortunately it doesn't bother my wife....
when insteon makes battery-powered remote control stick-on switches i may replace it....
Edited by jeffw_00 - March 29 2008 at 17:41
BeachBum
Posted: March 30 2008 at 13:38 | IP Logged Quote BeachBum
The only time it flickers is when Insteon traffic is present. X10 doesn’t bother it. The work around is anytime the track is on I run scan off and when off scan is running again. The load on the track is 470 Watts but what mystifies me is I don’t see it on any of the other ones. On another note, I run Micro-Brite dimmable CFLs with no load and I don’t get a flicker from anything including low dim.
Pete - X10 Oldie
ginigma
Posted: March 30 2008 at 13:54 | IP Logged Quote ginigma
I had load flickering issues before when the lamps were dimmed low. After a few calls to SH, they replaced them. No more flicker. Are they older Insteon switches? If so, there may have been a bad batch some where.
BeachBum
Posted: March 30 2008 at 14:11 | IP Logged Quote BeachBum
It is a new 600 Watt dimmer. I have tried others and they have the same problem. Right now I am running an X10 500 Watt dimmer on that circuit and it also gets the Insteon flicker. You won't see the flicker at full brightness.
Pete - X10 Oldie
jeffw_00
Posted: March 30 2008 at 14:45 | IP Logged Quote jeffw_00
it may not be the insteon module that causes the flicker, it's the traffic. I get flicker on lights not hooked into insteon modules
BeachBum
Posted: March 30 2008 at 14:53 | IP Logged Quote BeachBum
The only common denominator is the track and the Insteon traffic. Different Insteon and X10 dimmers have the same problem. Again it does not flicker on other circuits on the same phase. The only thing I haven’t changed out is the circuit breaker. I have a hard time believing it is at fault.
Pete - X10 Oldie
jbbtex
Posted: March 30 2008 at 16:08 | IP Logged Quote jbbtex
I have flicker from Insteon traffic on two different switches. They both have multiple bulbs and the load is near the rated limit.
On mine the flicker is only noticable when dimmed.
Brady
BeachBum
Posted: March 30 2008 at 21:07 | IP Logged Quote BeachBum
Ditto, now we’re getting close to the culprit.
Pete - X10 Oldie
patrickm
Posted: March 31 2008 at 10:15 | IP Logged Quote patrickm
I had this happen with a few dimmers a while back. Smarthome acknowledged a problem with with dimmers with large loads and replaced them without any grief.
BeachBum
Posted: March 31 2008 at 10:44 | IP Logged Quote BeachBum
The load is 2 tracks and I tried to isolate it down by disconnecting all low voltage devices and running only 4 R20 50 Watt bulbs. That would have given me 200 Watts on a 600 Watt dimmer but it still flickered. The other problem is the flicker also happens when using 500 Watts X10 dimmers. I have tried the ICON, which I think is rated at 300 Watts, and the 600 Watt SwitchLinc V2. Also in the same gang box I have another Insteon dimmer for another track with a 350 Watt load and it does NOT flicker.
I think you guys are right on with the culprit being the dimmer. Now all I need to do is find out which component(s) on the track are making the problem worse. I wonder if this is related to the triacs they use in both modules.
Pete - X10 Oldie
patrickm
Posted: March 31 2008 at 11:02 | IP Logged Quote patrickm
When I spoke to smarthome about the flickering problem I was told there was a problem with an inductor in the dimmer that was causing the problem. From my poking around inside keypadlincs, icon switches, and regular Insteon dimmers, the power supply and AC circuits look to be close to identical. I'd bet that the X10 stuff is probably similar circuitry, so it's likely it's the same inductor problem that they had with the switchlincs.
WayneW
Posted: April 03 2008 at 10:56 | IP Logged Quote WayneW
This was a known issue a year or two ago. SmartHome eventually fixed the inductor. Search techmall.com or cocoontech.com or accessha.com for more details. No formal recall was ever issued, but I think SH swapped units if you complained under warranty. If I recall correctly, it was loads that were close to the max rating of the switch and deep dimming was used.
Back to Top View WayneW's Profile Search for other posts by WayneW
