m0eman Newbie
Posted: December 20 2008 at 04:39 | IP Logged
I've been fighting with this for 2 nights, and had it resolved....but that
didn't last. For my 2414S...I've covered all of the basics:
-getport=COM1 (verified correct port)
-verified all cables/connections
-removed/reinstalled/restarted PH numerous times
-shutdown and restartedsdm3 and timer software numerous times
-Tried SDM3 235 and 308... 235 worked! isresponding=TRUE!!! Then I
added my ELKM1G ethernet to PowerHome, and nothing has worked
since. unresponsive...isresponding=False. Verified EVERYTHING was the
same as my short success when isresponding=true, but have had no
success since then.
I have (2) 2414S's and 3 computers, and cannot get isresponding=true
with any.
Posted: December 20 2008 at 08:04 | IP Logged
Check Setup-Controllers and select Insteon DM and uncheck any other controllers you may have and see what that does. Don’t forget to Reinit.
m0eman Newbie
Posted: December 20 2008 at 12:14 | IP Logged
Thanks for the reply. Yesterday after adding the ELKM1G (when the
2414S became unresponsive) I unchecked the ELKM1G in PH controllers.
When that did not restore isresponding=true, I completely removed the
ELKM1G from PH's controllers. Following each change, I restarted
PH, verified SDM3.exe was not running, and unplugged and restarted the
2414S.
"Insteon DM" is currently the only setup controller. I have not made any
changes to the "Insteon DM" controller, since it was working yesterday.
Is there anything I am missing?
Edited by m0eman - December 20 2008 at 12:18
__________________ --
Steve
Posted: December 20 2008 at 12:49 | IP Logged
You might try starting SDM3 before PH and check it there. You can type DM in the window of SDM3 then issue commands like isresponding.
m0eman Newbie
Posted: December 20 2008 at 13:07 | IP Logged
Thanks again. I have been working directly from SDM3 (not PH). The one
time I had success (isresponding=true), I switched to PH, and it worked fine
from there too. I have since been getting =false thru both PH and SDM3
interfaces. getport is correctly set in both PH and SDM3.
Steve
Posted: December 20 2008 at 13:33 | IP Logged
So that eliminates PH. The only thing common between 3 computers and 2 PLCs is the cable and the power source. I’m sure you have done a hard reset on the PLC.
m0eman Newbie
Posted: December 20 2008 at 14:12 | IP Logged
Yes..I have rebooted the PC (win2k Adv svr) many times. I do not need a
serial adapter with that PC (and I had success with it briefly). I just made
a new serial cable....still no luck.
Serial (PC) PH(RJ45)
1
2 --------------1
3 --------------8
4
5--------------7
6
7
8
9
Also, I moved outlets much further from the PC. Could this be a registry
issue (with the port)?
Edited by m0eman - December 20 2008 at 14:13
Steve
Posted: December 20 2008 at 14:40 | IP Logged
I’m hedging on the cable. If you load SDM by itself I would think that takes care of the registry problem as that has been the fix in the past. I meant hard reset the PLC not PC. Can’t help you with the cable breakout…
m0eman Newbie
Posted: December 20 2008 at 19:28 | IP Logged
I'm up and running now .... on my old PLC. I swapped to my old PLC (again)
and my old cable (again), using SDM3235 (again), but this time it works! I
installed and setup all of my newest switches (this time) BEFORE trying to
add the ELK. I still don't know why neither would work before. I'm going
hard reset the newer PLC, in hope that it will also work. Thanks for all your
help.
Steve
