snowjay Newbie
Posted: November 12 2006 at 15:51 | IP Logged
Now that I have things working, I see the polling of each individual device. After it discovered my links I went thru and had it recheck any not found links. They show up in the Pending window above the status checks.
Now with about 10 rechecks and 10 status polls, I keep seeing the status polls rotate every 10 seconds but in the completed operations window it logs a link recheck. But yet none of the link rechecks ever dissapear. Occasionally the rechecks will rotate and then I get a different log entry when that happens.
But it's been over an hour now and all of my link rechecks are still there and communnication is 100% to my devices.
I turned off status polling and now every 10 seconds I see the same link recheck completed operation yet there is no activity in the SDM log and all of the rechecks are still in the pending window.
snowjay Newbie
Posted: November 12 2006 at 16:40 | IP Logged
Well I solved my problem again. I deleted each of the "stalled" checking links and recreted them. That took the operation out of pending and now when I check links they work and then dissapear.
Posted: November 13 2006 at 16:11 | IP Logged
Snowjay,
Ive seen this problem occasionally pop up where the "Pending Operations" does not properly match the "Completed Operations". It's usually caused by some data problem on my end and I thought I had corrected them all. If it crops up again, can you take a screenshot of the Insteon Explorer with the problem and then shutdown PowerHome and email me a copy of your database? This will give me the info I need to find and fix the problem.
snowjay Newbie
Posted: November 15 2006 at 07:54 | IP Logged
Will do! So far it's been perfect since then. :)
