Posted: November 25 2005 at 08:27 | IP Logged
Can the Command drop-down be populated with only numbers (instead of Command 1, Command 2, etc.)?
This would allow typing in values instead of scrolling to select them.
Posted: November 28 2005 at 19:54 | IP Logged
I'll look into this. Should be easy enough. I'll check on it tonight and see if it can even be fixed with a SQL statement.
Posted: November 28 2005 at 21:05 | IP Logged
Sorry Tony...no SQL. The data is contained in the all_value view which cannot be updated in the runtime dynamically.
But...the change is in so it'll be available in the next beta.
Posted: November 29 2005 at 08:08 | IP Logged
Whoo hoo!
Any updated estimate for release?
Posted: December 02 2005 at 22:13 | IP Logged
Im hoping for the next couple of weeks. Ive nearly finished the Insteon support (however, Ive discovered a bug in the sendx10raw...it doesnt send any X10 ). SmartHome has promised a redistributable version of the Device Manager shortly so Im going to try and wait on that. If it's not soon, I'll just go ahead and release without it.
Posted: December 03 2005 at 08:21 | IP Logged
Sounds good.
