renard Groupie
Online Status: Offline Posts: 68
Posted: November 17 2017 at 11:33 | IP Logged
Dave:
I am now attempting to build the PH-side of my remote sensor capability. I slightly modified the PHPlugIn_Net source sample (changed the returned name string) and I am trying to load in into the Controller/PlugIn structure of PH. I have built the .dll and placed it into the plugins folder. I have registered the .dll. It is setup in PH as a Controller and as a PlugIn. When I reinitialize PH I get this error message:
An error occurred while loading Plugin: REMOTESENSOR. The return code is: -2.
I have a functional breadboard version of the sensor module and I am working on the serial read/write from Arduino to .NET. I will need the Plugin which controls the remote sensors to load (obviously) as well as push the received information into virtual devices defined in PH.
Any thoughts on loading the PlugIn so I can start with connecting the remotes to the Plug-In base?
Terry
__________________ Terry
Posted: November 17 2017 at 16:19 | IP Logged
Terry,
If you want to email me your DLL and TLB file, I'll try to work out getting it loaded on my system.
Im not quite sure what you mean when you say it is setup in PH as a controller. The plugin infrastructure should only require any setup in the
Plugins section.
If you want to send me source code, I can also take a look at it and see if anything is amiss.
renard Groupie
Posted: November 17 2017 at 17:52 | IP Logged
Dave:
Thanks for the offer of assistance. For some reason, I thought the PlugIns talked to devices using a virtual controller. I will remove the controller reference and see if that is the issue.
If that does not work, I'll send the code. Finishing the remote sensor project is a higher priority for me than the text message issue.
I will also send you some information on the Arduino side of the remote sensor process, both the hardware and the software.
Terry
Posted: November 17 2017 at 18:52 | IP Logged
Terry,
Checking the code, a -2 means that it could not find the DLL control. I tested on my system with the PH_Plugin_Net plugin and got the same thing until I
properly registered the control using the command in the register.txt file.
Just to verify nothing is wrong with your system, I would try registering the sample plugin and verifying that you can get that one to load.
renard Groupie
Posted: November 17 2017 at 19:08 | IP Logged
Dave:
Reregistered the .dll (reported successful registration) and no joy on the startup. Here is the command:
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe "C:\powerhome\plugins\RemoteSensor.dll" /tlb
Just sent you an email with a bunch of stuff.
Terry
