jeffw_00 Super User
Posted: January 25 2010 at 11:27 | IP Logged
Hi - I've been having some PLM issues, but whenever I swap PLMs, I have to manually delete and recreate all the links to/from the PLM (between PLM and things like KPL, Controllinc, Motion Sensor, etc). Admittedly for my small setup it's just 5 minutes of drag and edit, but since it's so mechanical. I wonder if there's an easier way (or an easier way coming in a new version of PH?) Seems like it would be a useful feature. Something like - simply update the address of the PLM in the link database and do a Save of everything? (rather than having to delete and recreate all the same links)
Just a thought - or maybe there's an easy way I'm missing?
Posted: January 25 2010 at 13:59 | IP Logged
This must be possible, as I did something similar going from a PLC to a PLM (no recreating anything).
Posted: February 01 2010 at 19:12 | IP Logged
The easy way to upgrade your PLC/PLM...
1. Shutdown PowerHome. Disconnect old PLC/PLM. Connect new PLC/PLM.
2. Start PowerHome. Open Help/About and go to "Controllers" tab. Note the address of the new controller.
3. Open Insteon Explorer. Uncheck "Enable Pending". Navigate to "Devices" tab. Find the ID for your new controller. PowerHome would have autogenerated a new one for you. Verify you've got the right one by comparing the address.
4. Delete this newly created line (next version of PowerHome, this will not be necessary). Save/Refresh to save your changes. Scroll down until you find the ID of your previous PLC/PLM. In the "Replace Address" field, type the address of your new PLC/PLM. Save/Refresh to save your changes.
5. Verify that your controller line looks proper with the correct ID and now the correct address. Make sure that the Insteon Type reflects your actual controller.
6. Prep the new PLC/PLM by performing the steps on the Setup Tab. If the new controller is a PLC, do a "Download", "Clear", "Add Min". If a PLM, do a "Clear", "Add Full".
7. Check "Enable Pending". At this time, PowerHome should start updating all your external devices with your new controllers address.
jeffw_00 Super User
Posted: February 01 2010 at 20:43 | IP Logged
Thanks Dave - we knew there was an easy way 8-}
jeffw_00 Super User
Posted: February 09 2010 at 19:26 | IP Logged
I know there's probably a fix for this, but, at least on my installation, step 7 didn't work. No updating occurred, and all the links were bad (ID and Descriptions show "ID NOT FOUND"). I had to rebuild all the links again (no big deal).
2 things
a) Could this be because i have most of the checkboxes across the top unchecked (no regular polling, etc).
b) Note to readers. After rebuilding the links, it pays to clear and reload the controller -again-. This extra step seems to be needed to make the motion sensor work.
Edited by jeffw_00 - February 09 2010 at 20:38
Posted: June 03 2011 at 01:22 | IP Logged
Grr. I thought I lost my PLM, so, I ordered another one. Help|About says that no controller is connected when I have the new one or old one connected. Digging in...
Posted: June 03 2011 at 03:42 | IP Logged
Under Powerhome Explorer; Setup | Controllers, is either PLM listed and checked Active? A Reinit may be needed to have Controller change take effect.
Edited by grif091 - June 03 2011 at 03:43
Posted: June 03 2011 at 12:41 | IP Logged
The one that's shown is Active.
I may have lost the serial port. Once I can test via loopback I'll know more.
Posted: June 03 2011 at 14:16 | IP Logged
Great. I can't get to the port with Hyperterm. It says that another app is using it. Next on the list is to see if it got disabled in BIOS and pick up an USB/serial adapter for alternate testing.
Posted: June 03 2011 at 14:33 | IP Logged
When you get done you may have two good PLMs.
Posted: June 03 2011 at 16:32 | IP Logged
The USB-Serial adapter is functioning and the new PLM is working. :D
I'll check out the old one later. This new one is dual-band, so, I think I have some additional options now.
